Shared View Panel has no options \ buttons
omriron
omriron
Hello!
I'm using revit 2021.1 .
My "shared views" panel have worked in the past and now it's completely empty
https://www.screencast.com/t/DA3ruvIBNhTn
is there a solution or an explanation for that?
ennujozlagam
can you try to uncheck your use hardware acceleration from options and updates your graphics driver to the latest and see if helps. thanks
omriron
Thank you @ennujozlagam
but still no luck...
https://www.screencast.com/t/hnve82tntd
i have unchecked "hardware acceleration", update drivers and restart...
same problem happens on my other computers such as my dell precision-5540, and another i7 with rtx2070
both with new and light sample revit  files...
ennujozlagam
is that a 3rd party plugin? if yes do a clean uninstall and reinstall again. thanks
omriron
hey @ennujozlagam  still no luck....
i did notice that it's working on a computer that have no addins installed
and i believe that the addin that cause it is: PYRevit
i have uninstall with the revit uninstall tool
then restart and install again
but the window still aint working...
maybe it has something to do with antivirus\firewall\specific ports i should open?
ennujozlagam
yes switch off your anti virus program and firewall then uninstall your PYRevit and see if is working maybe reinstall later. thanks
omriron
@ennujozlagam thank you!
