Shared parameters - adding own comments
mbednarzKYSGH
Message 1 of 9
mbednarzKYSGH
Hi!
Is there any option to add your own comments to .txt files with shared parameters?
I was trying to add them under chosen parameter using #.
The file is working but after adding a new comment the comment disappears.
Replies (8)
Message 2 of 9
RDAOU
@mbednarzKYSGH
No you cannot. Once you add a new parameter, the format will reset and delete your comments which are interrupting the file
BTW, if you are experimenting, which you seem to be doing, do consider reading the 2nd OOTB comment from the top
Why and what for do you need those comments!! This is neither C nor P coding so basically do not need to add comments. If it is for sorting purposes, when you are using the right editing software you can sort txt files using filters...This is supposed to be a simple tab delimited file and you should not edit it manually
Message 3 of 9
mbednarzKYSGH
Regarding to your comment,
I consider why these comment doesn't disappear and the rest (added manually) are.
Message 4 of 9
RDAOU
@mbednarzKYSGH
Appear and disappear where mate? did you read my previous reply?
Message 5 of 9
mbednarzKYSGH
Sorry my mistake, I missed some part of your comment, nvm.
I need to add some comments for people managing shared parameters - the tooltip could contain only 250 characters - to keep all info in one place - .txt file - instead of another repository for full description.
Message 6 of 9
RDAOU
@mbednarzKYSGH
Ok simple answer NO you cannot add such comment. Whenever you add new parameters from revit, those comments will be deleted automatically. The popup tool tip comment 250 characters are meant to give hints and not a full literature of the Shared Parameter Protocols.
There are other apps or plugin which are designed EITHER to manage OR edit the Sharedparameter.txt file and provide you with a comment section for you to type anything you want and as long as you want...BUT it just wont be in the SharedParameter.txt file if you know what I mean.
THe .txt itself
  1. one should NOT be editing it manually even if one is a Revit GURU
  2. one should NOT alter/disturb its format
  3. to respect the file format, any comments you want to add MUST be at the beginning of the file
Message 7 of 9
mbednarzKYSGH
Thank you for your help.
Could you quote some of these plugins/apps?
Message 8 of 9
RDAOU
@mbednarzKYSGH
There are many...not vouching for any but you asked for names so example: Diroots, ParaManager is/contain a parameter management function...if you search you should find several others
Message 9 of 9
Comments?  Where would they show?  Or do you mean Tooltip Description?
