Hello, I'm writing because of a weird problem i've stumbled upon.
I have in my model some area plans that are offset from reference planes.
These areas area boundaries are offset from reference planes by a value provided in global parameter. Now all it works like a charm for my BOMA calculations.
I've tried to do the same thing with Room Separators - everytime I set a dimension to a label corresponding to global parameter, and then change value of this global parameter the constraints become DISSATISFIED..
Can any revit guru explain the intricacies of the Revit API or software architecture itself that prevent these Room Separators from obeying parameter values? Ah, and the reference planes are Pinned, but unpinning yields the same result.
Whoa I just played with it a little more, and it seems that a workaround is to extend these Room Separators so they dont join at ends if otherwise then this seems to break constraints when global parameter is changed...
Below is the pic with constrains working...
Thanks Autodesk for another counter intuitive little bug to workaround ![]()
I have bad news for you...regardless if you extend/shorten the boundary lines, at one point it will not work neither for areas nor for rooms.
Some tools and feature are maybe not meant to be bent by or to the Users' will ...If you are looking for a sustainable solution for whatever you are doing, you will need to find a different way to do it.
Closed for sure it is if you are happy with what you have.
The reply was:
Happy, as in happy to be having to find workarounds for such problems in a industry leading software developed by a monopoly company with 3,2 billion USD of revenue... I learned I can only count on these kind of workarounds
<mellow rant over>
What about pulling the Global Dimensions between Room Separator Lines and Model Lines?
if one knows what exactly the purpose of this offset is one might be able to help you better. MAYBE ...
If you elaborate i am sure there is someone out here who can make your life easier
Unfortunately when dimensions are set to correspond to Global Parameter then Revit tries to break constraints by pulling Model Lines off their lock to Reference Planes
- Just maybe, a calculated value in a schedule or tag could be the thing you need ...
- it could be also something more complex what you are doing and ddynamois the solution
- Or maybe you are trying to workout some parametric conceptual design where Generative Design plugin might be ur answer
For now this workaround is sufficient for my needs, it's just a matter of having control of Room Separators offset from outline of the building - and most simple approach is suitable here. I did approach it with Dynamo generating these Room Separators but came to conclusion that this approach is not as flexible and more time consuming (having to run dynamo and run the script over just entering different value into Global Parameter)
I'm suggesting Model Lines in lieu of Reference Planes. Works for me. What is this for anyways? I'm supposing you are doing this to meet BOMA/Steet Frontage rules. Am I warm?
