Shared parameter and connection between components
- Mute
- Permalink
- Report
Hello all,
I hope you are doing well. I have two inquiries.
First, I made the sheared parameters as the project requirements, and each column must have its own parameters, but when I started adding the value to the column, it appeared that all the project's columns took the same values. How can I make each column unique and have its own shared parameter?
The second inquiry came when I took a simple example of two columns and one beam using a precast column and precast beam family. Then, when I started moving the column with the tool I created, the beam still connected to the column and expanded. How can I stop this connection?
Best,
