I'm pretty new to using revit so this could be a pretty simple fix. I created a two shaft openings on the second floor, one above my stair and the other above the main room. I'm trying to add my ceiling and then my roof, however when I do this the shaft opening is still visible and it won't let me create a ceiling over it. It's cutting the ceiling and roof. What am I doing wrong ?
Instead of using a Shaft to cut your stairwell opening, why don't you just edit the second floor boundary and sketch an opening in it?
