Basic Annotation of Ramp in plan view
adrian.troendle
adrian.troendle
I have been searching for a way to annotate the slope of a ramp with a number and arrow in plan view. The inclination is impossible to get and the only solution that I've found for the arrow was to create it in 3D view assigning the slopes as work planes and to draw on them with the 'Model Line tool', so that they are visible in all plan views. Shouldn't this be solved as an annotation family just like the stair ones?
syman2000
This is fixed in Revit 2022. If you are using previous version, there is no way to overcome this issue. Typically i would use slope floor so you get the slope annotation display on plan.
cbcarch
See if this helps: https://forums.autodesk.com/t5/revit-architecture-forum/spot-annotate-slope-of-a-ramp/td-p/9306422
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
adrian.troendle
I am still with Revit 2021 and I look forward for updates in our office.
Thank you for the answer.
mauricio_mssf
I did a Screencast explaining how to solve this in versions prior to 2022.
The problem is in the viewrange, adjust to a distance of an adjusted range of 4 feet (approximately 1.22 meters) then place the tag.
Place slope tag on Ramp on floor plan
https://knowledge.autodesk.com/pt-br/community/screencast/7ef0c4aa-1c49-4c0e-a908-abcdf8d7a6e7
There are some explanations of how the viewrange works at this link.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2014/EN...
Você achou esta postagem útil? Sinta-se à vontade para curtir esta postagem.
Ficou satisfeito com a resposta à sua pergunta? Nesse caso, clique no botão ACEITAR SOLUÇÃO.
 Mauricio Santos Filho Arquiteto | BIM Manager
