Spot annotate slope of a ramp
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
3107 Aufrufe, 5 Antworten
Hi experts,
I am trying to mark the slope of a handicap ramp but the tool keeps telling me that the ramp has no slope!
Thanks and regards
5 ANTWORTEN 5
Nachricht 2 von 6
RDAOU
als Antwort auf: Anonymous
@handybrandy
In 3D set plane to the ramp surface and place model lines at the edges...then in plan views use spot slope and tab select the model line
Edit: In versions priot to 2019 you could place the slope annotation on a floor then drag drop it on the ramp (not sure which Revit version you are using)
Nachricht 3 von 6
And also the arrow is missing or not working...thank you
Nachricht 4 von 6
RDAOU
@handybrandy
That was bugged too … you need to either live with the arrows of the spot slope or model a Line Based detail item which you can place manually
I think I have an old screencast … I will check and upload it if it's still there
Edit: See screencast below -
Nachricht 5 von 6
als Antwort auf: RDAOU
Thank you.
Do you have a tutorial how to build that family?
Nachricht 6 von 6
RDAOU
@Anonymous
It is a Detail Item Line based family
  • Add a line and lock to the horizontal plane
  • Lock the line's start and end points to the left and right planes
  • Add a generic annotation and lock it to the end with a Yes/No visibility parameter
  • you can also add another generic annotation (filled circle or a tick mark) to the start point
you can add 2 or 3 Arrows of different dimensions for various view scales...quite easy to model. You should try to model it yourself and if it doesn't work I will help you fix it.
