ifc export problem
5 REPLIES 5
1720 Views, 5 Replies
ifc export problem
Hello, I am trying to export a model to IFC, but when I open the IFC fyle I see that some walls exports as IfcWall but others exports as IfcWallstandardCase, in the mapping I have configurated as IfcWall. Futhermore, I have tried to change it with the parameter IfcExportAs butCaptura.PNG it does nothing, and also if I specify the IfcExportType paremeter doesn't modify it either.
Thanks for the help
Labels (1)
  • ifc
5 REPLIES 5
Marvi
Have you tried use the IFC exporter from the Autodesk App Store?
https://apps.autodesk.com/RVT/en/List/Search?isAppSearch=True&searchboxstore=RVT&facet=&collection=&...
in reply to: Marvi
Yes I've tried but I have the same problem.
Lance.Coffey
Thank you for the question @Anonymous!
I’m seeing a similar thread on this topic here: Changing IFC class for system families
In the thread above, it looks like the value was being controlled by the IFC Version that was being exported:
2x3 Coordination View 2.0 -> IfcWallstandardCase
IFC4 Reference View        -> IfcWall
In my testing (with a new sample model - attached) I am seeing similar results.
If this doesn’t work for you, could you reply with a sample model for further testing?
Lance Coffey
Technical Support Specialist
Hello, thank you for answering.
In my case in the version 2x3 I have some walls as IfcWall an others as IfcWallStandarCase, if I export in the version 4 all the walls are IfcWall. But I have to export it in 2x3 and I need all the walls as IfcWall, and if it's not possible I would like to undestand why some walls exports as IfcWall and others don't.
Lance.Coffey
I found the following definition from Building Smart for IFCWall with IFC2x3, that may answer why some of these walls are exporting differently:
IfcWallStandardCase  used for all occurrences of walls, that have a non-changing thickness along the wall path and where the thickness parameter can be fully described by a material layer set. These walls are always represented geometrically by a SweptSolid geometry, if a 3D geometric representation is assigned,
IfcWall  used for all other occurrences of wall, particularly for walls with changing thickness along the wall path (e.g. polygonal walls), or walls with a non-rectangular cross sections (e.g. L-shaped retaining walls).
Looking at the provided sample model, I’m seeing that 11 of the walls are exporting as IfcWallStandardCase, and two are exporting as IfcWall.
Here is a screenshot showing two of these walls:
From what I’m seeing, in the example above the floor cutting into the wall on the right, is causing that wall to have a sufficiently varying thickness to be output as the non-standard IfcWall (removing that floor then re-exporting changes the output so that both walls are output as IfcWallStandardCase.
Lance Coffey
Forma Design Contest
Technology Administrators
