Shadows not showing up when floor is drawn in
emilycross
Message 1 of 47
emilycross
I've been struggling to figure out why my shadows are only showing up outside the walls of this house, and I think I've narrowed it down to the floor. When I add a floor, the shadows cast by the interior walls are no longer visible. I'm a bit of a beginner at Revit, so I'm not sure what to try.
1. Floor is drawn at Level 2
2. Walls are drawn at Level 2
3. Shadows are set to be cast at Level 2
4. This happens on the floor plan view and the 3D view
I've attached images of flooring drawn, and one with it removed. It's also worth noting, we're working with Design Options in this project, though that doesn't seem to be affecting it, and I'm working in Revit 2021
Replies (46)
Message 2 of 47
Check your View Range Settings.
Can you post the file?
Message 3 of 47
hmunsell
in the view properties, check the Graphics Display Options and make sure Shadows > Cast Shadows is checked.
My Bad... never mind, ignore me.....
if that was unchecked you wouldnt get shadows on the outside either......
Howard Munsell
Message 4 of 47
JM_K
Emily,
Can you do a screencap of your Viewrange settings?
Insert witty comment here.
Message 5 of 47
ennujozlagam
delete existing 3D view and create a new one and orient to others view and apply shadows. thanks
Message 6 of 47
emilycross
I tried that, but thank you.
Message 7 of 47
Are you going to post the file?  That might be the next troubleshooting step. Make sure it is replicable by others.  If it ain't, then the problem could be hardware related.
Message 8 of 47
emilycross
See attached, thanks!
Message 9 of 47
Nothing unusual in this screenshot . What am I looking for?
Message 10 of 47
emilycross
Message 11 of 47
syman2000
Can you check what level shadow is set to?
Message 12 of 47
Hello?  Same screenshot posted as before. What's wrong with it?
Message 13 of 47
emilycross
Yes, the shadows/ground plane are set to the correct level.
Message 14 of 47
emilycross
@barthbradley  someone else had asked for it
Message 15 of 47
Message 16 of 47
syman2000
Post the file so we can take a look what is wrong. I cannot replicated your issue using our own sample file.
Message 17 of 47
WHAT IS WRONG WITH IT?
Message 18 of 47
emilycross
Hope this helps.
Message 19 of 47
What's wrong with it, Emily?
Message 20 of 47
emilycross
What's wrong with what? I explained my issue in the original post.
