Separating Revit Backups By Settings
Duvylove
Duvylove
Hi All,
Please, is there any settings in Revit that can separate where backups are saved by default. I would prefer my backups to be saved in a different folder in relation to my original/main file Why? I often mistakenly open the backup files instead of the original file and this could be frustrating at time
I look forward to hearing from you all
Thank you
Regards
RDAOU
@Duvylove
A built in option no there isn’t..
  1. you can schedule a .bat file to move them daily or on startup see this post here (Solved: Revit Backup Files - Autodesk Community)
  2. use a 3rd party plugin (there are many that organizes backups). The followig is not a recommendation, only an example: Backup File Organizer | Autodesk App Store
handjonathan
Hi @Duvylove
Thanks a lot for posting your question to the forums!   Has the solution suggested by @RDAOU helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
Duvylove
Yes. I have installed the app and accepted the solution above
handjonathan
Thanks for coming back to me and glad you got all sorted @Duvylove
Jonathan Hand
