Section symbol scale
eng.girgis.adly
Message 1 of 8
eng.girgis.adly
Dears,
when I change the View scale from (1:100) to (1:400) some of the sections symbols in the drawing become very big and the others disappears
so How can I solve this problem ?
Replies (7)
Message 2 of 8
vitorbortoncello
Hi, select the symbol and change the scale at "hide at scales coarser than"
Please, if this post has helped you, choose accecpt as solution
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | BIM Manager
dAutodesk Certified Professional
Message 3 of 8
mhiserZFHXS
@eng.girgis.adlyThe symbol doesn't become bigger. Everything else gets smaller. You can create a new section head that is smaller if that's your desired outcome.
@vitorbortoncello's solution is probably why some of them are disappearing.
Message 4 of 8
eng.girgis.adly
do you have a guide for how to create a smaaler section head ?
Message 5 of 8
mhiserZFHXS
Editing an existing one would be the most straightforward way.
Message 6 of 8
vitorbortoncello
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Customizing-the-se...
Message 7 of 8
You sure you want to do that?  You might want to place both the 1:100 and 1:400 views on a Sheet and see the difference in the Section Symbols.  There is none.  They will both be the same size.  For legibility/readability, I wouldn't suggest a font size smaller than 3/32".   If that's their size now, you might change the View Scale/View Extents instead.  FWIW.
Message 8 of 8
Sections already shown in 1:100 views need not shown again in 1:400 views.
Also, if you repeat the sections across different scales, they are still the same sections and thus, using the same symbol.  You cannot just show one section with big symbol in one view and show the same section with a small symbol in another view.
