Properties and Project browser
3 ANTWORTEN 3
Nachricht 1 von 4
petruzzi
261 Aufrufe, 3 Antworten
Hello, my properties and project browser are not on top of eachother anymore, how do you put them back one on top of the others and now as windows one next to each other, which i need to open everytime one at the time.
Many thanks
3 ANTWORTEN 3
Nachricht 2 von 4
eizinmyat
als Antwort auf: petruzzi
You do not need to set every time. Once you set, it is ok. Place the cursor on the brown part and press left click. And then move to the left below until the blue shaded pattern appears. If the pattern appears, you can place there.
Ei Zin Myat
Technical Sales Unit Engineer
ONESTRUCTION Co., Ltd.
eizinmyat@onestruction.com
Nachricht 3 von 4
petruzzi
als Antwort auf: eizinmyat
Sorry I didnt understand can you please reexplain? Thank you
Nachricht 4 von 4
jay_colcombe
You can Drag on one top of the other and then use the Tabs at the Bottom to Switch
If this is an Still an issue following you can reset them back to default.
Project Browser or Properties window is missing in Revit (autodesk.com)
Jay Colcombe
Autodesk Certified Instructor
