Wall layer line in plan view disappears after join walls
giles_reed
giles_reed
Hey,
I was wondering if anyone else has this.
I have a compound wall made up of 2 walls, and I join them for the window cut-outs.
When I join them I loose the plan layer line where the 2 walls meet.
First image walls un-joined
2nd image walls joined
any thoughts?
G
vitorbortoncello
Change the layer priority by setting the wall 2 layer to a lower priority. If they are both same priority, change the material, so the line appears at the join.
For more info:
https://help.autodesk.com/view/RVTLT/2022/ENU/?guid=GUID-1CCD1005-CBDA-4338-8D60-489095D4BB25
Did you like the post? Don't forget to Like and mark Accept as Solution.
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | BIM Manager
dAutodesk Certified Professional
Sounds like you are saying that you DO NOT want to remove the linework between the joined walls layers. If this is correct, then DO NOT join them.  Join Geometry will always remove linework at the union of similar materials.
If you need the Walls joined at the Window in order for the Opening to penetrate through all, then Split the Walls at and Window and join just those Walls or use a Wall Opening to create the Window Opening.
giles_reed
Thats correct, I want to conserve the line between the two walls ...
