section showing different view
vincenzo_ialunaALYH8
Message 1 of 11
When I create a section (red line in the screen)through the room and open it, instead of seeing the interior sectioned, I see the building’s exterior (green line in the screen) as if the section wasn’t made through the room but outside the building. It’s like the exterior elevation of the building, which is parallel to the section cut inside the room.
Replies (10)
Message 2 of 11
RDAOU
@vincenzo_ialunaALYH8
You might have probably clicked "Reference other View" option by mistake
Message 3 of 11
thank you for your help.
but in the modify section there is nothing showing. is there another way to find it?
Message 4 of 11
RDAOU
You have to recreate it…
the option is there when I are first placing it. After you are done, you can see on the properties pallet that the section which opens is section 2 which is outside the building
Message 5 of 11
i did a new section and didn't click reference other view but there is the same problem.. maybe is something else?
Message 6 of 11
RDAOU
How about u upload that Revit file? 🙂
Message 7 of 11
thanks, attached the file!
Message 8 of 11
RDAOU
This is happening because you modeled the walls as an In Place family >> Extrusion and you have used the Category Furniture
  • Furniture Category is not Cuttable
  • If you wish them to be Cut by the section line, you need to change the category to Wall or Generic Model  (See GIF below)
The question is why are you modeling them as In Place extrusions and Not Archtiecture >> Wall
Message 9 of 11
THANK YOU SO MUCH!
i was in a hurry and thought model in place would be  quicker
Message 10 of 11
I have another problem with visibility in another file if you are so kind to help me again 🙏. if i import dwg on floor plan i don't see it but in 3d model i see it.
Message 11 of 11
RDAOU
If you are linking a DWG into a plan view or a section/elevation and want it to be visible in all views, make sure the "Current View Only" option is unchecked.
P.S.: Instead of importing, use linking—importing a CAD file can clutter your model with unnecessary elements.
