Section markers visible in 3D views
I think I know the answer to this but thought I throw it out there before I post it on the ideas page.
Is there a way to see section markers in 3D views? At the moment it's clunky to be in 3D, want to jump to a relevant section but then have to go to plan view, work our which one relates then double click it. I may be missing something but I can't find a way of showing it.
If it's not an option then with the addition of levels in 3D views in 2019 it's surely an easy add-in for those clever friendly Revit programmers. Smiley Very Happy
If you are in a 3D view, just activate the section box and cut a live 3D section instead of opening a 2D section.
No such luck I am afraid.
What are you trying to achieve, I didn't quite understand your post regarding jumping to a section. Would using the view cube to orient the section box to the section you want assist?
In the default 3D view the section box is greyed out. How do I select it?
**Edit** My bad, it was the selection box that was greyed out, not the section box. How do I orient the view to a section? Using the viewcube?
Right click on the view cube and select 'Orient to View > Sections' then select the one you want.
Section box will cut your model from that section...
Wohhh!! Did not know about that. That is just superb. This is going straight into my go-to commands list. Thanks fellas.
