Wall wrapping issue when joining a column
Hi all,
Please see attached photo's.
I have a problem with the wall layers in plan view when i insert a door or column. I do no know what causes the problem. For some reason i no not have this problem is wrapping at inserts is set to "do not wrap" (image B). as soon as i set the wrapping at inserts parameter to "both" the wall layers get messed up. If i remove both doors in the wall the problem disappears. If i leave the doors, and remove the concrete column, the problem also disappears. What i need is a wall with wrapping set to "both" and the column and 2 doors in the wall.
Thanks!
cbcarch
Try splitting the wall at the column--instead of running it continuously past the column.
Also, it looks like you need to add furring/finish walls to the column--unless it will truly be exposed?
If so, then you will have some more wall joins to clean up.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
