section line width proplem
mohamedsafy
mohamedsafy
hello there
i have a problem with the section line style , it is appearing wider than the width i gave to it in the object style i double checked it's category and all the sub categories that can be related to it and checked that there is no override graphics for it in the view template and as you see in the second photo the section line have same line weight as the wall but the section line as appearing wider
1
2
aRcHiTeCt.JM
.... the thin lines is turned on ?
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
mohamedsafy
thank you for your answer
but that is not the problem , the problem is " although both of the wall and the section line have the same line  weight ( 4 ) assigned to them "
the section line appears to be wider than the wall line
Check the line weight table and see what value are set for number 4 for both annotation and model, for the scale of the view. They CAN be different.
mohamedsafy
perfect !
thank you
