effects in view
effects in view
effects in view
Hi people. How can I make this in revit? How can I get those effects? Or do I have to make a room in revit and then go to photoshop to apply the effects?
aRcHiTeCt.JM
… hi @Anonymous
…. Yes, you can do it totally and completely in REVIT
… you don’t need Photoshop for that matter
… you can use DECALS to apply the texture to those walls
…. Or you can create a model in-place wall an apply the texture as a material
…. Or simply a wall and a ceiling with texture
…. Either way is same result
… how to apply decals?
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2015/EN...
… and for the furniture:
… that is just glass with more reflective settings applied
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
aRcHiTeCt.JM
.... even the silohuettes are RPCs
.... I have a couple of those if you  need
aRcHiTeCt.JM
REVIT EXPERT ELITE
