hello there
i have a problem with the section line style , it is appearing wider than the width i gave to it in the object style i double checked it's category and all the sub categories that can be related to it and checked that there is no override graphics for it in the view template and as you see in the second photo the section line have same line weight as the wall but the section line as appearing wider
1
2
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
.... the thin lines is turned on ?
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
thank you for your answer
but that is not the problem , the problem is " although both of the wall and the section line have the same line weight ( 4 ) assigned to them "
the section line appears to be wider than the wall line
