Cannot find draw panel in Revit LT 2019
Message 1 of 10
I am going through the tutorial videos for Revit 2019. In the create a level tutorial the video shows a draw panel  on the "Modify" tab of the ribbon. When I am on that tab in my install of Revit 2019 there is NO draw panel. HOw do I get it on the ribbon?
The ribbon (in Modify) has Properties, Clipboard, Geometry, Modify, View, Measure and Create, but NO Draw
This makes it impossible to follow the tutorial - what am I doing wrong?
Accepted solutions (3)
Replies (9)
Message 2 of 10
Sahay_R
What you see in the Modify panel depends upon what it is that you have selected. When you have regions, floors, roofs, selected, then you will get an option to Edit Boundary. When you click on Edit Boundary, then you will see the Draw panel.
Select object>>Modify>>Edit Boundary>>Draw
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 3 of 10
aRcHiTeCt.JM
.... @Sahay_R right on the spot
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
Message 4 of 10
aRcHiTeCt.JM
.... you need to click in anything and turn that blue
... then you will get your ribbon full of stuff
aRcHiTeCt.JM
REVIT EXPERT ELITE
Message 5 of 10
Yet there is no draw panel on your example picture.
Message 6 of 10
LMAO true
Also having same issue
Message 7 of 10
depatterson
Observer
Observer
Nope. That didn't work either. Clicked on something, no draw panel.
Message 8 of 10
depatterson
Observer
Observer
Is nobody going to answer this question correctly? Every answer from a so-called 'Expert' has been blatantly incorrect. Can we get someone who actually knows the answer?
Message 9 of 10
RSomppi
Wow. You're quite judgemental for someone seeking help.
Those tools don't show up until you are actually drawing something.
Message 10 of 10
hogni
Community Visitor
Community Visitor
Try to start drawing a detail line (DL). When in the command you get the draw menu.
If for instance you want to fillet two lines that you have already drawn it is not enough to select them both.
Instead, start the DL command - than the draw menu appears - select the fillet icon - select the lines - than you can deside the radius.
