Section line markers not showing
twhitwell6
12,897 次查看
24 条回复
1 条消息(共 25 条)
twhitwell6
Hello all,
I am having an issue on Revit LT 2021. I have a plan with 2 sections applied to it; 4 of which I have on one sheet, one above the other. 3 views are displaying the section line markers for the other sections, apart from one. I have check the visibility graphics and sections are marked as on; the lightbulb to the toolbar bottom left shows no hidden section lines; and the "hide at scales coarser than" is set to a high scale and the same as the other section views on the page. To my knowledge, all four section views on the page have the same settings. I have even checked the far clip offset to see if the view would be beyond the offset but that all seems grand.
All the issues online point towards the "hide at scales coarser than" but this isnt my issue (i think). I ve attached a screenshot of my sheet and views.
Any help muchly appreciated, thank you
0 个赞
已接受的解答 (2)
12,898 次查看
24 条回复
回复 (24)
2 条消息(共 25 条)
Check the Phase of the View.
...Check through this list:
Missing Something in a Revit View? 33 Steps to Find Stuff | Ideate Inc
0 个赞
3 条消息(共 25 条)
twhitwell6
Unfortunately none of those apply. Theses exact same section lines are showing in the views on the same sheet with the same properties.
0 个赞
4 条消息(共 25 条)
Maybe I misunderstood. Are you saying the Section Markers are just not showing on the Sheet, but they do show in the View itself?
0 个赞
5 条消息(共 25 条)
twhitwell6
No they don't show on the sheet or in the view. However they do show in other views which have the same properties
0 个赞
6 条消息(共 25 条)
Okay. I find it hard to believe nothing in that list applies.  Is the View's Far Clip intersecting the Section Marker?  Set it to No Clip.
...do those unseen Markers Reference other Views?
0 个赞
7 条消息(共 25 条)
johna
What does the plan view look like? make sure the extents of the sections extends to the wall elevation. as well as try "reveal hidden" just in case..
__________________
Criticize but don't hate
0 个赞
8 条消息(共 25 条)
twhitwell6
All the section markers are visible in the plan view, and I have checked all the extents to ensure they should be visible. Real hidden shows nothing
0 个赞
9 条消息(共 25 条)
twhitwell6
It is already set to no clip
0 个赞
10 条消息(共 25 条)
twhitwell6
0 个赞
11 条消息(共 25 条)
Number 27 would be the Far Clip I mentioned above - assuming those Section Markers are in front of the Section Marker that created that View.
0 个赞
12 条消息(共 25 条)
Can you post the file?
0 个赞
13 条消息(共 25 条)
twhitwell6
I have checked all the extents of the far clip of both the section view where the markers are missing and the 6 markers that should be showing. nothing seems amiss
0 个赞
14 条消息(共 25 条)
Have you checked the Cut Plane of the Marker creating the View?
0 个赞
15 条消息(共 25 条)
twhitwell6
All seems to be correct. The one thing maybe I mentioned that was incorrect was that the view is an elevation not a section, however the other views on the page are elevations as well and they are happily showing the section markers
0 个赞
16 条消息(共 25 条)
That wouldn't change any of the above feedback.  Are these unseen Section Markers of the Type the reference another View?  I asked this above.
...can you just post the file so we can dispense with the guessing?
0 个赞
17 条消息(共 25 条)
twhitwell6
Yes they are, sorry i must have missed that question. I will try and post the file now.
0 个赞
18 条消息(共 25 条)
twhitwell6
Please see the file attached. The issue im having is on sheet "0203 - Ground Floor - Internal Elevations 01" and the elevation is "0F - Internal Elevation South - Hall"
0 个赞
19 条消息(共 25 条)
Yes, they are Referencing Other View???
0 个赞
20 条消息(共 25 条)
已接受的解答
If the section lines are not perpendicular to the elevation view then they will not show in that view.  Workaround, place sections on that view and reference the actual section views.
0 个赞
