section box
section box
arkitek2ss
section box
arkitek2ss
is there a way to keep the retain section box in 3D view after its been turned off and back on again?
something else....
there a way to create an irrregular shape section box in 3D View?
RLY_15
  • Use a Scope Box to define the Section Box. Scope Boxes are persistent.
  • Section Boxes are rectangular, so unfortunately no. For spinning a 3D view around, you would have to use visibility control on the areas outside of interest. For placing on a sheet, you could try layering multiple 3D views with partitioned Section/Scope boxes to create the irregular shape.
mari.shimode
Hi @arkitek2ss, did the information provided answer your question? If so, please use Accept Solution so that others may find this in the future.
If you still have the issue, please let us know. Thank you.
Mari Shimode
arq_42
yo could vote here:
https://forums.autodesk.com/t5/revit-ideas/non-rectangular-scope-box/idi-p/6330700
¿Te resultó útil esta publicación? Dale "Me gusta".
¿Tu pregunta fue respondida correctamente? Haz clic en "ACEPTAR SOLUCIÓN".
