Changing the appearance of the User Interface
geteway2digitalindia
After changing the default colour of the working area from white to black, is there any way to make other zones on screen - Project browser, Properties panel, Quick Access Tool Bar, Ribbon.. etc all black
RDAOU
@geteway2digitalindia
If you go to graphics options there is a dark mode
imankassab2015
 windows way to use magnifier on windows then use  invert magnifier colors to ctrl+ alt +I inside it as shown in the attached image make sure that magnifier is set to 100 % as shown on the attached photo to get out from magnifier press windows + esc
accept my answer if it helps you
arq_42
what?
Literally what @RDAOU has said:
File/Options/Colors/UI active theme: Dark
Edit: My apologies, I saw that it must be a new feature in Revit 25 or 26.
¿Te resultó útil esta publicación? Dale "Me gusta".
¿Tu pregunta fue respondida correctamente? Haz clic en "ACEPTAR SOLUCIÓN".
imankassab2015
it is in version 2024 too ..
