Section Box not visible in 3D view (Revit 2024)
AlexromeroB3QB7
AlexromeroB3QB7
Hi everyone,
I’m having trouble with the Section Box in Revit 2024. In my 3D view, I enabled the Section Box option in the Properties palette, and I also checked that it is visible in Visibility/Graphics - Annotation Categories - Section Boxes (it’s turned on).
However, I still cannot see the section box rectangle in my 3D view.
  • Verified that the Section Box is enabled in the 3D view properties.
  • Confirmed that “Section Boxes” is checked under Visibility/Graphics.
  • Switched to plan and elevation views to see if the box was far away from the model.
  • Duplicated the 3D view and re-enabled Section Box.
The strange thing is: if I create a new project file, the Section Box works fine and I can see/adjust it normally. The issue only happens in this file (which has linked models).
I’m attaching the project file/link here so you can check it directly.
Thanks in advance!
Basam.Yousif
lol
It is hidden BY ELEMENT 😉
AlexromeroB3QB7
Thank you so much! I spent a couple of hours that night struggling with it until I finally gave up. I completely overlooked the existence of the “Hidden” tool — total beginner’s mistake! 😞
RSomppi
Laughing at someone is rude. We've all run into this at times, some multiple times. It's not a laughing matter even if it appears to be simple. This forum is not about that. It's about support.
