I am new to Revit and learning it from open source you tube videos, now I have to create a parametric Mild Steel water tank with rectangle/square(50X50) MS pipes as stiffeners. There are vertical stiffeners and horizontal stiffeners. I have created parameters for changing the length and breadth of tanks and it is working fine. I have also added parameter for height. Now, If I add one sweep (Stiffener) around the tank, it is working well with length and breadth changes but once I create array along the height of the tank, the sweep is not expanding/contracting with the walls the tank. I want all the elements to be parametric (Height, Breadth and Width of walls, horizontal stiffeners and vertical stiffeners)
"I want similar one.jpg" is sample tank what I am trying to draw.
"SBR Tanks MS.rfa" is the file I am working
