Section Box not visible in 3D view (Revit 2024)
AlexromeroB3QB7
Observer Observer
AlexromeroB3QB7
Observer
Observer
Hi everyone,
I’m having trouble with the Section Box in Revit 2024. In my 3D view, I enabled the Section Box option in the Properties palette, and I also checked that it is visible in Visibility/Graphics - Annotation Categories - Section Boxes (it’s turned on).
However, I still cannot see the section box rectangle in my 3D view.
  • Verified that the Section Box is enabled in the 3D view properties.
  • Confirmed that “Section Boxes” is checked under Visibility/Graphics.
  • Switched to plan and elevation views to see if the box was far away from the model.
  • Duplicated the 3D view and re-enabled Section Box.
The strange thing is: if I create a new project file, the Section Box works fine and I can see/adjust it normally. The issue only happens in this file (which has linked models).
I’m attaching the project file/link here so you can check it directly.
Thanks in advance!
Basam.Yousif
lol
It is hidden BY ELEMENT 😉
AlexromeroB3QB7
Observer
Observer
Thank you so much! I spent a couple of hours that night struggling with it until I finally gave up. I completely overlooked the existence of the “Hidden” tool — total beginner’s mistake! 😞
RSomppi
Laughing at someone is rude. We've all run into this at times, some multiple times. It's not a laughing matter even if it appears to be simple. This forum is not about that. It's about support.
blank...
"There will be no laughter, except the laugh of triumph over a defeated enemy."
