Scheduling GUID
Scheduling GUID
Scheduling GUID
Hi - is it possible to schedule out GUID values from Revit into an excel file?
RDAOU
@Anonymous
You need dynamo to extract them...then you can write to excel straight to excel or back to Revit then excel
How to get the Revit elements GUID and IFC_GUID using Dynamo - Packages - Dynamo (dynamobim.com)
luisPDAN6
You get element ID numbers by default in the first column when using the Database Editor. Have a look in the Revit App store and download the trial version. One can then filter what element you look for and export to Excel, PDF and print.
Matt_Keck
Has there been and development on this? being able to capture the Element ID and best and the GUID with a Revit schedule would be extremely valuable for exporting from Revit and importing into other software for visualizations and key column mapping needs.
ralphdenhaan
In Revit 2023 and 2024, you can add the IfcGUID to your schedules and then export it to Excel.
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
LinkedIn | LazyBIM Blog
Matt_Keck
Looks like I will be upgrading to 2023, interestingly the ifcGUID parameter is listed as an option to schedule in 2022 but it doesn't return any values. That's unfortunate.
