Schedules: Sum of Grand Totals per Columns
zakim
Message 1 of 12
zakim
This post is related to my earlier posting HERE ... but I am separating them due to its nature.
My question: how can I take the Grand Totals of certain columns and include them in a formula.
See my screen capture below.
Can Revit do this or is this a Dynamo task?
I appreciate any feedback.
Replies (11)
Message 2 of 12
SteveKStafford
Will adding a footer in the Sorting/Group tab for the items you are grouping by get you there?
Steve Stafford
Message 3 of 12
zakim
Hello @SteveKStafford  - I already have footer in the schedule. Did I understand you correct?!
Message 4 of 12
SteveKStafford
Enable calculations for the User parameter C so you'll get sub-totals for each group and and grand total at the bottom for that column too. I probably misunderstand what result you want.
Steve Stafford
Message 5 of 12
zakim
Hi @SteveKStafford. Just to clarify more, I am trying to make "User Parameter C" a formula that gives one value. based on the following logic:
User Parameter C = SUM (User Parameter A) / SUM (User Parameter B)
In other words:
User Parameter C = Grand Totals of (User Parameter A) / Grand Totals (User Parameter B)
Message 6 of 12
User Parameter C = User Parameter A + Unser Parameter B
Formatting tab > set User Parameter C to Calculate Totals
Message 7 of 12
SteveKStafford
I think I understand now. You want each row to show the result of dividing the total value at the bottom of the schedule for A and B. You can calculate across the row, A/B and show that value but not the result of math on the total of the column. I also don't understand how that provides a meaningful result for a single door?
I have seen people use the Percent of Total option to create occupancy calculations where they need to count things and provide a value that works back from the total of something to an individual calculation but I'm not certain that concept will work in this case. I'll post a link when I find the article I'm thinking of.
Steve Stafford
Message 8 of 12
SteveKStafford
See if Tim's post on his BLOG here might work to get what you want.
Steve Stafford
Message 9 of 12
zakim
I tried the Second Work around and I was able to solve it.
Thank you @SteveKStafford for taking time to help me solve this.
Message 10 of 12
zakim
Hello again @SteveKStafford ... I guess I have another follow up question.
Please see the example in the attached screen capture. I wonder if it is possible to grab the "Sub-Total" values of each "Sub Section" in order to preform perform a calculated formula.
I feel that I should stop doing this stuff in Revit due to the limitations and better do it in Excel.
Message 11 of 12
SteveKStafford
Separate schedules, filter each so you only include a single level and use the grand total?
Steve Stafford
Message 12 of 12
zakim
This is an acceptable workaround for 2-3 levels, but is hard to manage when there are many levels (e.g. 20). Thanks.
