Schedule Yes/No is it possible to auto hide columns with a No value?
capu57XX5R9
capu57XX5R9
Is it possible to have a schedule column not show up on a sheet when a yes/no parameter is set to no?
I know how to set up the yes/no parameter and have it set so yes = "●" and no = "".  So no is blank.  We have our schedule so certain columns in the header are vertical and centered and gray hatch.  Too many people are deleting this columns when they do not want to see them instead of just hiding them.  So every time we have to re-add those columns we have to go through the somewhat minor hassle of reformatting it to match the standard.  Is it possible to have the columns marked with a NO for the parameter in question, autohide/not show up on a sheet?  Then if that sheet is changed to a Yes for whatever parameter that column will then show up again on the sheet the schedule is on?
I have a feeling this is not possible based on what I have read this morning but figure if it was possible someone her most likely would know how to do it.
GustavoUbriaco
Hi
Yes it's possible with filter option
Gustavo Ubriaco Contreras
 Deleting the Column From the Schedule? LMAO!  Are they at least Duplicating the Schedule first?
No.  But you can add (Do Not Delete, I am looking at you Steve) to the column header.
