Schedule Wood Columns
1 REPLY 1
avacath1122
167 Views, 1 Reply
I figured out how to make a schedule for WF columns in order to total the length of them, but I'm having trouble doing this for the architectural wood columns. When I add the length parameter it shows up empty in the schedule, what might I be doing wrong??
1 REPLY 1
RDAOU
in reply to: avacath1122
@avacath1122
Architectural Column family does not have an OOTB length parameter you need to do 1 of the following
  1. either use a calculated values
  2. Or edit the family and add a shared parameter Length between the 2 reference Levels in the family (this will be automatically set to Instance Reporting) - See GIF below
Forma Design Contest
