Walls hatch in plan view
5 ANTWORTEN 5
Nachricht 1 von 6
arc2lab
8991 Aufrufe, 5 Antworten
I have a problem with wall hatch that shows up in plan view, that different walls have hatch going different direction (please, see the image). The hatch of walls that shows up is diagonal, although coarse scale fill pattern is set to solid fill. Also, in visibility graphics all settings for walls are set to no override. Any help would be appreciated.
Laura
5 ANTWORTEN 5
Nachricht 2 von 6
Keith_Wilkinson
als Antwort auf: arc2lab
Is there a view filter applied?
I assume you checked the Graphics override for the Cut Pattern for the wall?
K.
"Give a man a fish and you feed him for a day; teach a man to fish and you feed him for a lifetime."
Maimonides
Nachricht 3 von 6
arc2lab
als Antwort auf: Keith_Wilkinson
No, there is no view filter applied, and there is no override for the cut pattern.
Nachricht 4 von 6
Keith_Wilkinson
Without seeing the file then it's hard to say.
You could try creating a view template from another plan view and try applying that to your problematic view.  If it solves the problem you will know it's something in your VG settings that's causing the problem then you just need to find out where it is.
Maimonides
Nachricht 5 von 6
loboarch
Laura
Looks like it could be the "Orientation in Host Layers" setting on the fill pattern.  The "align with element" setting will have this affect.
You can check this setting and try changing it to "orient to view" if it is not set that way already.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
Nachricht 6 von 6
ST10122891
als Antwort auf: loboarch
Thank you so much your advise was really helpful!
