Schedule Text Sizes
8 REPLIES 8
Message 1 of 9
ksoltis
1757 Views, 8 Replies
Schedule Text Sizes
ksoltis
We're having an issue with our sheet schedule and text sizes. The text is showing on the sheet at 3/32" no matter what text type and size is used. I've compared the schedule to other projects and can't find any differences in the settings. This one has me completely stumped, any ideas?
Schedule Text Sizes
8 REPLIES 8
Message 2 of 9
hmunsell
in reply to: ksoltis
hmunsell
i assume you are changing the text settings in the Schedule Properties > Appearance tab?
Howard Munsell
Howard Munsell
Message 3 of 9
The schedule text may be overridden directly in the schedule (highlight and change font size and style).
Message 4 of 9
ksoltis
in reply to: hmunsell
ksoltis
You are correct.
You are correct.
Message 5 of 9
ksoltis
in reply to: ToanDN
ksoltis
I don't have the option to change text that way in the sheet schedule, only through the appearance tab.
Message 6 of 9
Remove any view template assigned to the schedule then you can.
Message 7 of 9
hmunsell
in reply to: ToanDN
hmunsell
Right next to the Font button @ToanDN is showing is also the Reset button. if you select the column and pick the reset button it should "reset" it to what is specified in the appearance tab settings.
Howard Munsell
Howard Munsell
Message 8 of 9
ksoltis
ksoltis
That was it, thank you all!
Message 9 of 9
troy_pastorello
troy_pastorello
Community Visitor
Community Visitor
My schedule properties are greyed out. I don't see how to un gray it so I can make changes?
