I am just putting a few schedules together in our Revit templates and have come across an ordering issue when I try and sort them by Associated Level.
So I have created a View schedule with two sorting actions the first is the family (header is ticked also), then the associated level (ascending). The schedule does not put the levels in order correctly. (see below screen shoot)
Has anyone else come across this and if so how did you get around it?
Gareth
Hi @Anonymous
How are you doing?
I'm checking back to see if you had a chance to post to the Ideas forum? Once you do please post the link here, so others can upvote your idea and add a comment for further consideration.
If you find posts have helped or solved your problem, please click on 'Accept as solution' to help others with similar questions.
Thanks!
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
This was added to the Idea's forum, please see link below.
View Level Organisation in View Schedule
Thank you, @Anonymous
Viveka CD
