Revit 2017 bug with linked files
5 ANTWORTEN 5
Nachricht 1 von 6
SamKeville-NBBJ
284 Aufrufe, 5 Antworten
 I've found a new pesky error when working with linked files.  When I select a link and accidentally hit create similar, it locked up and shut down revit.  Anyone else find this?
5 ANTWORTEN 5
Nachricht 2 von 6
cbcarch
als Antwort auf: SamKeville-NBBJ
Sounds like expected behavior, as creating similar Links is not a good idea!
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Nachricht 3 von 6
als Antwort auf: cbcarch
@SamKeville-NBBJ: No; it doesn't happen to me.
Nachricht 4 von 6
SamKeville-NBBJ
als Antwort auf: barthbradley
what happens for you when you hit cs?
Nachricht 5 von 6
RobDraw
Not a bug. It works as expected here.
Rob
Nachricht 6 von 6
SamKeville-NBBJ
als Antwort auf: RobDraw
What's the expected behavior when using create similar on a link?
It seems not everyone is getting a full crash, what's anyone getting as a result instead?  Does it do nothing?  Does it start an import?
