Schedule formula
Schedule formula
Message 1 of 13
Schedule formula
thanks in advance.
I am trying to created an override formula. I need some help.
I have a door type, in this case a storefront door, which is apart of difference storefront groups.
I want to be able to do an instance override frame type, for certain frame types (storefronts) with out having to duplicate a storefront door each time. the same door goes into different size storefront frame systems.
I would like this to show up in the schedules.
Replies (12)
Message 2 of 13
Make the Frame Type an instance parameter instead of a type parameter.
Message 3 of 13
I am trying to create a calculated parameter formula like this in my door schedule
IF(OR([DOOR SCHEDULE - FRAME TYPE OVERRIDE]),yes= [DOOR SCHEDULE - FRAME INSTANCE (Override)], no=[DOOR SCHEDULE - FRAME TYPE (Type)]
Message 4 of 13
Is FRAME TYPE a text parameter? If so, it doesn't work in a formula.
Message 5 of 13
Stanis-74
make screenshoot on your family types window.
formula "yes/no" can`t be based on "text" parametr. there is no needs to wright "yes" in condition "yes" in "yes/no" formula  (same for "no")
revit formula syntax: https://www.revitforum.org/tutorials-tips-tricks/1046-revit-formulas-everyday-usage.html
Message 6 of 13
yes it is, so whats a work around to achieve this. I'm sure there a way to set something up like this without having to create a new frame stype for every storefront door.
Is the formula not going to read the frame style text because its an instance and not a type?
Message 7 of 13
Stanis-74, I overlooked your comment he it is.
Yes I have been looking over that page, but I haven't been able to figure out what I am doing wrong
Message 8 of 13
Stanis-74
i`m not sure that understand you right, but chek this:
here in feild "Choose..." you need to number of type that you want to use. name of the types i write in field "result".
if it is not what you need, please, explain step by step what you have now and what you want.
Message 9 of 13
@Anonymous
Use number or integer for Frame Type so the formula can work.
Message 10 of 13
So you are creating a formula inside the Door itself and not in the schedules?
Message 11 of 13
Stanis-74
Message 12 of 13
All,
I have successfully figured out the formula to add with the help of someone else.
if you look at the .png files I added to create the parameters what I did next was go to my door schedule and created an additional "Add calculated Parameter"
there I created a formula with
Discipline: Common
Type: text
Formula: if([DOOR SCHEDULE - FRAME TYPE OVERRIDE], [DOOR SCHEDULE - FRAME INSTANCE (Override)], [DOOR SCHEDULE - FRAME TYPE (Type)])
What this does is when the door frame type override is checked, it refers to the instance, if its not it check it will reference the type
Message 13 of 13
@Anonymous
Well done!
