Grid show up on both sides when it is linked into my model. After I go in and turn off the left side. Any Idea on how to get this to look thay way I want it? Thanks
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Hi
have a look in the Grid Options..
Both in the main file and the linked file..
End 1 - keep checked
End 2 - uncheck it..
hope that will resolved the issue.
Cheers!
I think you should copy/monitor the grids from the link file to your file so that you will have a complete control of how they look and their 2D extent for individual views.
You could just use the copy/monitor tool to copy the grid from the link to the project, and then turn off the grid bubbles.
