Schedule Footer Opacity
11 REPLIES 11
Message 1 of 12
chughes
1000 Views, 11 Replies
Is it possible to control schedule footer fill color?  I know that typical cells shading color can be adjusted by a single digit to make them 'white' and opaque.  I cannot find where the footer can be changed.
11 REPLIES 11
Message 2 of 12
in reply to: chughes
like this?
Message 3 of 12
chughes
in reply to: barthbradley
I believe so, yes.  Whereabouts mightn't I find that adjustment?
Message 4 of 12
It is a slight pain in the buttocks to do.  It's a solid-colored Fill Region on the Sheet -- which itself is a workaround since Revit doesn't allow Filled Regions to be placed on a Sheet.  Do you want to go there?
1. In Sheet View: Draw a Detail Line and Group it.
2. In Model Plan View: Place instance of Group and edit it.
3. In Group Edit mode: Draw a Rectangular Solid-Colored Fill Region and click Finish to close out of Group Editing mode.
4. In Sheet View: Select the Group (now a Rectangular Solid-Colored Fill Region) and edit it.
5. In Group Edit mode: resize the Rectangular Solid-Colored Fill Region and click Finish to close out of Group Editing mode.
Message 5 of 12
Create a Legend view 1:1 with a masking the same size as your footer and place it on sheet where the footer is.
Message 6 of 12
chughes
in reply to: ToanDN
This probably works probably the best.  Adding reference planes to the legend background allows for edge alignment.
Message 7 of 12
The approach of using a region on sheet works too.
- draw detail lines on sheet first
- group them
- place the group in a drafting view and add a masking/fill region
- the group on sheet with be updated with the region
Message 8 of 12
I've used both approaches. Six of one; half-dozen of another. I just happen to prefer the Fill Region on Sheet better.
Message 9 of 12
chughes
After working with the grouped detail region option, I have changed my opinion and agree that the grouped detail region works better.  I do want to note that the region has to be a Filled Region.  A Masking Region will not work.
Message 10 of 12
I never said masking region. Where did that come from?
Message 11 of 12
chughes
ToanDN mentioned masking/filled region, and I mentally defaulted to masking region thinking of 'masking' something.  I wanted to point it out for clarity, for others reading the solution.
Message 12 of 12
Ian_Shafer
Has anyone (including Autodesk) found a real solution to this? Adding 'pasties' to a drafting view isn't very BIM.
Forma Design Contest
