Schedule Count
8 REPLIES 8
Message 1 of 9
13210 Views, 8 Replies
Schedule Count
Hello, I have a situation where I have different components in my projects. Some of these components I have used multiple times. On my schedule each of the components have their rows even the duplicates(each of the multiple times ones).
What I want is for each component to have just one row, so if they are used multiple times the count only should be the one to increase.
I looked at the following:
https://www.revitforum.org/architecture-general-revit-questions/10386-schedule-count-question.html
https://forums.autodesk.com/t5/revit-architecture-forum/scheduling-assemblies-count-field/m-p/620497...
However when I apply the same solution by unchecking itemize every instance, I get only 1 row. One row representative of all my components.
Just a bit of background,all my components were made using metric generic model, the type mark box is empty.
Thank you in advance,
8 REPLIES 8
Message 2 of 9
Sahay_R
Generic Models can be moved over to different categories. That will solve your problems.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 3 of 9
in reply to: Sahay_R
Thank you for your reply, how do I do this? Do I go into the individual family, highlight them and change a particular setting in properties?
Message 4 of 9
Sahay_R
Yes. Open the individual family and change the Categories
Generic Models can be changed over to most categories, except Mass. This should solve your problem.
If you could mark my reply as an accepted solution, that would be great. Thank you!
Rina Sahay
Message 5 of 9
artejon
To change a category you have to edit a family and pick Category from Create panel.
If you want your components to stay as generic models then you can also try to sort your schedule by family/type or any other parameter.
Revit add-ins: CAD Purger (delete UNUSED and selected line patterns & line styles, find and delete CAD), Rooms To Spaces, Schedule Utilities (Calculated Values/Combined Parameters To Tags, reuse view filter rules in schedule filters), View Filter Manager at Revit Apps Store
Message 6 of 9
@Anonymous
Read the​ attached PDF for a better understanding how schedules work.
Message 7 of 9
Have you set the "Count" field to calculate totals in the formatting tab?
Message 8 of 9
Alisder.Brown
Hey
What are you sorting your schedule by?
The "itemize every instance" option, when unpicked, will group them by whatever is in your "Sorting/Grouping" tab within your schedule. See image below. This is sorting rooms by their level, then their Department (as an example)
I hope this helps 🙂
Alisder Brown
Senior BIM Coordinator
Scotland, UK
Message 9 of 9
Thank you for the replies and answers much appreciated. I pretty much got to the solution using the same logic @Alisder.Brown
Forma Design Contest
Technology Administrators
