Scaling dimensions for detail
CRJFusco
Message 1 of 8
CRJFusco
I am looking to made a simple 2d drawing that will be used multiple times in a project as a standard detail. In this detail there is a blow-up that I want to dimension but it is not to scale. The detail is a notch 1" high, 1/2" deep and a 1/2" slope to the flat. When making the blow up the numbers are 4x larger then they should. Is there a way to scale the dimension to show the smaller number?
Replies (7)
Message 2 of 8
1/16" text is really the smallest you should use.  Work backward from there.
...View Scale.
Message 3 of 8
- Override dim value with text and append an Unicode at the end
- or create a detail of the notch, change scale, and place it on the same sheet in the main detail area, w/o a view title
Message 4 of 8
CRJFusco
Please see attached of what I am trying to do with the blow up needing to be 1/4 the size shown.
Message 5 of 8
Not sure to whom you addressed but both of what I offered above are for this condition.
Message 6 of 8
Looks like a call-out to me.  Just place the 2 views on the same sheet.  No?
About Callout Views | Revit 2020 | Autodesk Knowledge Network
Message 7 of 8
Message 8 of 8
hmunsell
So you have all the linework drawn in one Detail/Drafting view, it is not an actual live callout...
Just make 2 different Dimension Styles, one for 1/8" and one for 1/16" (or what ever sizes you want them to represent at).  Assign the appropriate dimension style size to the appropriate text.
the .25 dimension is set to Bldg_Ticks 1/16" Dim style
the 1.75 dimension is set to Bldg_Ticks 1/8" Dim style
Howard Munsell
