RVT Exporter STL error - Ghost objects
6 REPLIES 6
Marielen_
505 Views, 6 Replies
I would like help to understand how to solve:
When generating STL file does it show objects or elements that do not belong to revit in the original project? Image:foto5.JPG
In red, an apparently lost object from my original project (in blue)
Tags (2)
Labels (1)
6 REPLIES 6
Lance.Coffey
in reply to: Marielen_
Thank you for the question @Marielen_!
My first thought would be that the unexpected objects seen in the STL do exist in the Revit project, but may not have been visible.
What have you done to confirm that the highlighted stair (from the provided image) was not in the Revit project? (The following help topic covers some things to check when: Objects Are Not Visible.)
Lance Coffey
Technical Support Specialist
Marielen_
in reply to: Lance.Coffey
Because I disabled all hidden modes, I found that this happens when I set the option "export in shared coordinates" (image), when I don't choose that option, that ladder does not appear.
Lance.Coffey
Thank you for the update @Marielen_!
Can you attach a sample RVT, so that I can test the export on my system?
Lance Coffey
Marielen_
Hey, I resolved the issue, there was a link that was not appearing, but it was active.
Thank you for try!
Lance.Coffey
This is interesting, it sounds like the visibility for linked models is changing when the option to include linked models is turned on in the export to STL dialog.
Lance Coffey
Marielen_
Exact, but the structure was not complete, besides exporting to a completely different location. Thanks for note!
Forma Design Contest
Technology Administrators
