Rotating 3D
Rotating 3D
Luke.Kemel
Message 1 of 29
Rotating 3D
Luke.Kemel
Hi there,
I have designed a façade panel mock up that has an angle of 6degrees. I have drawn the mock up in a flat 90degree plane, but I cannot seem to rotate this to achieve the design spec angle of 6degrees. can someone assist please.
I am presented with an error box saying some element will be deleted, why is this?
Replies (28)
Message 21 of 29
Sure. Don't place the family on the level. Draw a reference plane @ 6 degree angle, name it. Then edit your family like I show, and place it on the reference plane.
Message 22 of 29
Luke.Kemel
see attached
Message 23 of 29
Luke.Kemel
I have done as instructed and used the 6degree lean .ref but it wont create a suitable host. see attached
Message 24 of 29
Can you share the RFA?
Message 25 of 29
Luke.Kemel
please note this was in the first instance supposed to be for a visual purpose only. this has not been set by parameters or multiple ref planes.
I ideally needed a quick turn around but I have been stumped by this issue I have, so for personal gain I plan to detail this in more depth, I am just insure how yet!
Message 26 of 29
Luke.Kemel
Hi ToanDN,
Have you managed to review the file?
Message 27 of 29
Just did.  Didn't have to change a thing in your family.
- Draw a reference plane on an elevation @ 6 degree slope
- Load the family and choose Workplane, pick the reference plane, choose a Plan view to place
- Place it, select the instance and Space Bar to rotate it 90 degree on plan
- Go to the elevation to see the result
Message 28 of 29
Luke.Kemel
That's brilliant thank you! ive just followed your steps and its worked great, thank you
Message 29 of 29
chrisplyler
Yay!
