Rotate texture of a custom hatch
Hi Friends, Could you please let me know how to Rotate texture of a custom hatch. I attached the sample. Capture.PNG
Ilic.Andrej
If its a model hatch, you can just hit <tab> while hovering it. This should allow you to select one of its lines. Then, you can just use rotate tool and by rotating that line you will rotate the whole hatch.
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
