Add opening line to window family
Hi Friends, Can anyone let me know how to add an Capture.PNGopening line to window family. I attached a file for clarification.
dferreira-blackwell
edit the window family, go to plan view and add model lines in sub category projection. Select them -->convert Line--> to symbolic lines. done.
@Anonymous: I would also add that you should constraint them and dimension them as well, so they flex with the Window sizing.  Take a look at the OOTB Revit Casement Window Families and see how it's done as a parametric nested family.
