Rotate texture of a custom hatch
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
252 Aufrufe, 1 Antwort
Hi Friends, Could you please let me know how to Rotate texture of a custom hatch. I attached the sample. Capture.PNG
1 ANTWORT 1
Nachricht 2 von 2
Ilic.Andrej
als Antwort auf: Anonymous
If its a model hatch, you can just hit <tab> while hovering it. This should allow you to select one of its lines. Then, you can just use rotate tool and by rotating that line you will rotate the whole hatch.
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
