Two layers of a wall to show different materials in plan view
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
indiana_j0nes
1573 Aufrufe, 6 Antworten
I would like to show a wall in plan view with different materials.
I can achieve this in section but the plan shows the same material, any guess what i might be doing wrong?
Thankyou for your tips.
Kunal Tuljaram Gaidhankar
6 ANTWORTEN 6
Nachricht 2 von 7
joe_keogh
als Antwort auf: indiana_j0nes
Hi @indiana_j0nes
Check the detail level of the plan view.  Coarse will show ... well Coarse detail level, and medium and fine will show more detail.
Joe Keogh
Director | Design Technology + Innovation
www.viewlistic.com.au
Nachricht 3 von 7
check the height of the wall and the View Range value , so to be sure the wall is cut int your Plan View..
Constantin Stroescu
Nachricht 4 von 7
indiana_j0nes
als Antwort auf: joe_keogh
Thankyou for your reply Joe,
I am in fine detail level. Still. Something very simple is off.
Nachricht 5 von 7
I actually would like to see the wall in two layers in plan view without having the wall to be cutting through in plan view.
Imagine this to be a skirting, and I want the skirting to show two different materials in plan view.
Nachricht 6 von 7
indiana_j0nes
I figured this cant be done in plan view: but there are three workarounds
https://forums.autodesk.com/t5/revit-architecture-forum/material-surface-pattern-for-walls-in-plan-v...
Nachricht 7 von 7
Sounds like you are describing a Stacked Wall.  Maybe the lower wall one representing a wainscot?  Have you thought about modeling it that way? As a Stacked Wall?  Doing it that way would allow you to TAB-Select each Wall independently and modify their graphical representations in the view (i.e. Graphic Overrides by Element).
