Rotate Everything 90degrees
We're working on a site adapt of another project we have modelled through complete CD drawings. The new site is rotated 90degrees. Is there a way to rotate EVERYTHING in the new model? I'd like the details, enlarged plans, etc to rotate and carry over as well. If I change the Project North, all our text and annotations will not move?
thanks.
Why don't you do it the other way -- rotate the Site 90 degrees?
Are you familiar with Project North and True North View Orientations? Rotate your Site 90 degrees in the Building Model/Documentation Project, and then set "Angle to True North" to -90.  Then you can toggle the View "Orientation" between Project North and True North (e.g. North at 12 o'clock).
Definitely rotate the Site (and True North if you are not using shared coordinates).
