how to modify fill pattern on floors
marcbartolucci
Message 1 of 14
marcbartolucci
hello,
In the project I am working on, I have a floor finish plan, where I want to visually show the different floors, their alignment and orientation throughout the building. I set it up so that each room has interior finish text info in the properties menu. So I type in all of the different finishes in that room (such as GWB on each wall, carpet floor, ACT ceiling), which is then linked to a room finish schedule. I am using a custom view template, with a colour scheme to assign different floor types to different rooms (carpet, tile, wood, etc.).  Then within that colour scheme, I assign a fill pattern to represent the different types of flooring. So when I type into the properties that the floor in room A has carpet, this gets added to a  schedule, and the fill pattern appears on the floor plan.
The problem, is that as far as I can tell, I cannot edit the way that the flooring is shown on the plan. So I cant select the pattern like model lines, and move or rotate them as desired (like you could with ceiling tiles on a reflected ceiling plan). Is there a way to edit the fill pattern on the floor? Or perhaps there's a better way of doing this?
Thanks for the help, please describe in detail
Replies (13)
Message 2 of 14
Color Scheme Fill Patterns are Drafting Patterns.
What about a Floor Finish Color Scheme using Colors and/or Fills?
Message 3 of 14
hmunsell
so your using a Color fill schedule to place the floor pattern i the rooms, correct? you also want to be able to align the patterns as needed in each room?
if that's the case i don't think you can. The pattern placement in the Color Legend cant be adjusted like it can be if you use a floor with a pattern on it.
Howard Munsell
Message 4 of 14
You can go to Manage Tab=>Additional Settings=>Fill Patterns to create new Fill Patterns (Drafting Type) to use in your Color Scheme key.
Message 5 of 14
Room Color schemes use drafting patterns so you can only use them to indicate different floor types, not the actual floor patterns. For such, you need to use one of the follows:
- split face the floor an paint each area with a material
- create parts from the floor and change parts materials
- draw thin finish floors with different materials
- draw model pattern filled regions
Message 6 of 14
marcbartolucci
So I think that is what I am doing, so if I understand, this method means thats a drafting pattern, which means I cannot move the lines around like with model lines?
Message 7 of 14
marcbartolucci
Oh I see... so if I wanted to control the pattern of the floor in each room, I would need to make different floor types, and put different floors in each room? Is there a way to just add a hatch to the floor somehow?
Message 8 of 14
hmunsell
We typically use the "draw thin finish floors with different materials" method in my office. 🙂
Howard Munsell
Message 9 of 14
That would be the first method posted above.
Message 10 of 14
A Color Scheme is just a key. Why are you concerned with the alignment of the Fill Pattern?  Why does it matter?
Message 11 of 14
hmunsell
You could put a Filled Region in each room if you prefer. A Filled Region would only be visible in the view it was placed in. if you use a Model pattern as the filled region, you should be able to adjust it as needed. it would take almost the same amount of work as placing a floor with a material (my preferred method).
Howard Munsell
Message 12 of 14
marcbartolucci
So I like the idea, and I am trying to do it this way, but is there a way to make the pattern with model lines? I want to be able to align and rotate the pattern as needed directly on the plan, but cant figure it out.
Message 13 of 14
Surface Patterns are coming from the Graphic Properties of the Material the element is using.  If you use Model-type Patterns you can align those types.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2015/EN...
Message 14 of 14
hmunsell
...but is there a way to make the pattern with model lines?
There is the this method... 🙂
From the Architectural ribbon > Model panel > pick Model Lies...
Howard Munsell
