We're working on a site adapt of another project we have modelled through complete CD drawings. The new site is rotated 90degrees. Is there a way to rotate EVERYTHING in the new model? I'd like the details, enlarged plans, etc to rotate and carry over as well. If I change the Project North, all our text and annotations will not move?
thanks.
Why don't you do it the other way -- rotate the Site 90 degrees?
Are you familiar with Project North and True North View Orientations? Rotate your Site 90 degrees in the Building Model/Documentation Project, and then set "Angle to True North" to -90. Then you can toggle the View "Orientation" between Project North and True North (e.g. North at 12 o'clock).
