Rotate & Copy Doubles Rotation Angle
rmarkowitz
Message 1 of 45
rmarkowitz
When I rotate an item in Revit using the rotate command and I want to make a copy, the new instance of the item appears 2x the angle that I entered. If I want to rotate and make a copy of something at 45°, I must type in 22.5 as the rotation angle.
Is anyone else having this problem? It's not the worst problem in the world but is sure is annoying...
Thanks!
Replies (44)
Message 41 of 45
Arno.delange
looks like the problem is sitting into the Disjoin in the options bar... when rotating make sure it is turned OFF
Message 42 of 45
VascoP
I have this problem when "disjoin" is ticked, if it is unticked it works as it should
Message 43 of 45
stephen_gibbDJJ6J
Thanks for this thread. On Revit 2025.2 and this started happening also. Unticking the Disjoin sorted it.
Message 44 of 45
hwo_osa
The issue here is also that the "disjoin" checkbox cannot be unchecked whenever the "copy" option is active.
Effectively, this means that you cannot copy-rotate a workplane based family in Revit.
This thread is now over 5 years old and has almost 6.000 views. Come on Autodesk, seriously...
Message 45 of 45
jflemaydesign
I've had the same problem in Revit for years (about ten years) over multiple versions.  Rotating an object in the project by a certain angle, rotates it by twice that angle.  So to rotate by 60°, I have to type in 30°.  I now use Revit 2023.1, and the problem is very much there (e.g. rotating a face-based family in the project).
Unticking "Disjoin" seems to solve the problem.  But it still seems like a bug.
