After installing roombook... plugin, revit started to lag between view windows.
Is there some fix?
Thank you
Is there some fix?
Thank you
Solved by Viveka_CD. Go to Solution.
I've uploaded required data.
I'll wait for your feedback.
Meanwhile I cannot have Roombook installed since, as you already saw, performance is very degraded.
Thank you
Thank you
Hi I already upload
please help, its taking too long,
Hi I already upload
I had messaged you earlier.
Sorry about the delay. The issue is still under investigation. I will let you know as soon as I hear back from development.
I appreciate your patience, while this is being tested for a resolution.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
Viveka CD
I wanted to share an update with you:
This issue has been confirmed as a bug. Thanks for reporting this.
The development team was able to reproduce this issue in Revit 2018 and 2019 when Roombook is installed. There is a noticeable delay when opening views. If the add-in is disabled, and Revit is restarted, it is faster opening \and also when switching views.
Please try the below in the meantime:
For the customer in the meantime, if you are not using Roombook you can simply move the 3 addin files (Buildingbook.addin, Areabook.addin and Roombook.addin) that are located in C:\ProgramData\Autodesk\Revit\Addins\2018 to some other temporary location.
I will watch out for any future updates from the bug report. Feel free to ping me @Viveka_CD to check back.
Viveka CD
Viveka CD
Is there any solution for reported bug?
Thank you.
Thank you.
Thanks for checking back with me.
Yes, I confirmed the status we the dedicated team has made some progress on this issue.
I will have more information on the public information regarding this fix in a couple of months.
Feel free to check back and thank you for your patience while this is in progress.
Viveka CD
Viveka CD
Hello again,
Is there any progress?
Hello again,
Thanks for checking in.
Let me circle back with the team for any updates.
Meanwhile, make sure you have the latest updates and new security releases installed.
Viveka CD
Viveka CD
Hi there @rui_es_pacheco
Please keep an eye on the AKN article: When Roombook add-in is installed some operations in Revit are slower
Updates will be added to the article once the issue is resolved.
Viveka CD
Viveka CD
Is there any new developments?
I already installed last update to revit 2019, from yestarday, and installed again Roombook, and the issue mantains.
I really want those functionalities back without lagging.
Please help.
Please help.
